Tools
Introduction
Go to step 1 ↓RAM, or random access memory, is short-term storage for your ASUS U30SD-XA1. RAM is used by your processor for immediate use as-needed, unlike long-term files written to a hard disk drive. If your computer has slowed considerably or you’re looking for a boost, replacing/upgrading the RAM is a fairly simple and inexpensive first step. The ASUS U30SD-XA1 laptop comes standard with 8GB of RAM and can be upgraded to a maximum of 16GB with its two (DDR3) slots.
To replace the RAM, take and hold the new RAM by the sides, with the gold edge facing down towards the device.
Line up the top corners of the new RAM with the top edges of the now empty panel.
Slide the RAM into the slot until it's firmly in place.
Now just screw the panel door back on and you're finished!
Your new ASUS U30SD-XA1 RAM is ready to go. Now your device should run and work faster!
2 other people completed this guide.
