ASUS Transformer Book Flip TP500LA RAM Replacement
    1. ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: step 1, image 1 of 3 ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: step 1, image 2 of 3 ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: step 1, image 3 of 3
      • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
      Ask FixBot
    2. ASUS Transformer Book Flip TP500LA RAM Replacement: step 2, image 1 of 2 ASUS Transformer Book Flip TP500LA RAM Replacement: step 2, image 2 of 2
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • 'Slide a heavy-duty spudger in between the back case and the computer.
      • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
      • Gently lift off the back case.
      Ask FixBot
    3. ASUS Transformer Book Flip TP500LA RAM Replacement: step 3, image 1 of 2 ASUS Transformer Book Flip TP500LA RAM Replacement: step 3, image 2 of 2
      • Grasp the edges of the RAM case with your fingers.
      • Slowly lift the case upwards to remove the RAM case.
      Ask FixBot
    4. ASUS Transformer Book Flip TP500LA RAM Replacement: step 4, image 1 of 3 ASUS Transformer Book Flip TP500LA RAM Replacement: step 4, image 2 of 3 ASUS Transformer Book Flip TP500LA RAM Replacement: step 4, image 3 of 3
      • Loosen the RAM's fastener clips by lifting one of the clips as you grasp the RAM card.
      • Carefully lift it away from the motherboard.
      Ask FixBot
9 other people completed this guide.
Solomon Dovinh
435 Reputation
2 Guides authored
Cal Poly, Team S13-G5, Forte Spring 2017 Member of Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
3 Members
48 Guides authored
1 Guide Comment
Thank you very much, easy to understand instruction. Where could I buy the parts like the RAM?
Marc LeBouthillier - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 125
All Time: 3,359
