ASUS Transformer Book Flip TP500LA Fan Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
96
All Time:
2,440
Comments: 5
5 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The fan is responsible for self cooling the computer during operation. Without a working fan, your computer is prone to overheating and continually shutting down. This guide will help you replace your faulty or broken fan in your ASUS Transformer Book Flip TP500LA.
Tools
    1. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: step 1, image 1 of 3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: step 1, image 2 of 3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: step 1, image 3 of 3
      • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
      Ask FixBot
    2. ASUS Transformer Book Flip TP500LA Fan Replacement: step 2, image 1 of 2 ASUS Transformer Book Flip TP500LA Fan Replacement: step 2, image 2 of 2
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • Slide a heavy-duty spudger between the back case and the computer.
      • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
      • Gently lift off the back case.
      Ask FixBot
    1. ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: step 3, image 1 of 2 ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: step 3, image 2 of 2
      Heavy-Duty Spudger
      Buy
      • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
      • Pull the blue tab to remove the ribbon.
      Ask FixBot
    2. ASUS Transformer Book Flip TP500LA Fan Replacement: step 4, image 1 of 2 ASUS Transformer Book Flip TP500LA Fan Replacement: step 4, image 2 of 2
      • Remove the three 5 mm Phillips #0 screws.
      • Remove the single 6 mm Phillips #0 screw.
      Ask FixBot
    3. ASUS Transformer Book Flip TP500LA Fan Replacement: step 5, image 1 of 2 ASUS Transformer Book Flip TP500LA Fan Replacement: step 5, image 2 of 2
      • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
      • Gently pull the connector away from the motherboard.
      • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
      Ask FixBot
    4. ASUS Transformer Book Flip TP500LA Fan Replacement: step 6, image 1 of 2 ASUS Transformer Book Flip TP500LA Fan Replacement: step 6, image 2 of 2
      • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
      • Slide the battery out from the computer to remove.
      Ask FixBot
    1. ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: step 7, image 1 of 2 ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: step 7, image 2 of 2
      • Unscrew the six 5 mm Phillips #0 screws.
      Ask FixBot
    2. ASUS Transformer Book Flip TP500LA Fan Replacement: step 8, image 1 of 3 ASUS Transformer Book Flip TP500LA Fan Replacement: step 8, image 2 of 3 ASUS Transformer Book Flip TP500LA Fan Replacement: step 8, image 3 of 3
      Buy
      • Grasp the top of the 3-pin connector with tweezers.
      • Wiggle the connector until it loosens itself from the motherboard.
      • Gently lift the connector from the motherboard attachment.
      Ask FixBot
    3. ASUS Transformer Book Flip TP500LA Fan Replacement: step 9, image 1 of 1
      • Carefully lift the fan off the motherboard.
      • Attached to the fan is thermal pasting that needs to be reapplied when attaching the fan back to the motherboard. Follow this guide to reapply thermal pasting correctly.
      Ask FixBot
4 other people completed this guide.
Solomon Dovinh
435 Reputation
2 Guides authored
Cal Poly, Team S13-G5, Forte Spring 2017 Member of Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 96
All Time: 2,440
