ASUS Transformer Book Flip TP500LA Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
111
All Time:
12,299
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In this guide, we will show you how to access and remove the battery of the ASUS Transformer Book Flip TP500LA. This guide will assist you in replacing your dysfunctional battery with a new one.
Parts
Tools
    1. ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: step 1, image 1 of 3 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: step 1, image 2 of 3 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: step 1, image 3 of 3
      • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
      Ask FixBot
    2. ASUS Transformer Book Flip TP500LA Battery Replacement: step 2, image 1 of 2 ASUS Transformer Book Flip TP500LA Battery Replacement: step 2, image 2 of 2
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • Slide a heavy-duty spudger between the back case and the computer.
      • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
      • Gently lift off the back case.
      Ask FixBot
    1. ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: step 3, image 1 of 2 ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: step 3, image 2 of 2
      Heavy-Duty Spudger
      Buy
      • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
      • Pull the blue tab to remove the ribbon.
      Ask FixBot
    2. ASUS Transformer Book Flip TP500LA Battery Replacement: step 4, image 1 of 2 ASUS Transformer Book Flip TP500LA Battery Replacement: step 4, image 2 of 2
      • Remove the three 5 mm Phillips #0 screws.
      • Remove the single 6 mm Phillips #0 screw.
      Ask FixBot
    3. ASUS Transformer Book Flip TP500LA Battery Replacement: step 5, image 1 of 2 ASUS Transformer Book Flip TP500LA Battery Replacement: step 5, image 2 of 2
      • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
      • Gently pull the connector away from the motherboard.
      • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
      Ask FixBot
    4. ASUS Transformer Book Flip TP500LA Battery Replacement: step 6, image 1 of 2 ASUS Transformer Book Flip TP500LA Battery Replacement: step 6, image 2 of 2
      • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
      • Slide the battery out from the computer to remove.
      Ask FixBot
16 other people completed this guide.
Garrett Fitzpatrick
892 Reputation
2 Guides authored
Cal Poly, Team S13-G5, Forte Spring 2017 Member of Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
3 Members
48 Guides authored
1 Guide Comment
Power not responding?
Tamer Elhelaly - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 111
All Time: 12,299
