ASUS TUF Gaming FX505DY CMOS Battery Replacement
    1. ASUS TUF Gaming FX505DY CMOS Battery  Replacement, Back Case: step 1, image 1 of 1
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
      • Flip the laptop so the back is facing up.
      Ask FixBot
    2. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: step 2, image 1 of 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
      • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
      Ask FixBot
    3. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: step 3, image 1 of 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: step 3, image 2 of 2
      • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
      • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
      Ask FixBot
    4. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: step 4, image 1 of 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: step 4, image 2 of 2
      • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
      Ask FixBot
    1. ASUS TUF Gaming FX505DY CMOS Battery  Replacement, CMOS Battery: step 5, image 1 of 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement, CMOS Battery: step 5, image 2 of 2
      • Gently insert the narrow end of a spudger beneath the CMOS battery and push in, raising the battery.
      Ask FixBot
    2. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: step 6, image 1 of 1
      • Remove the battery from its socket at an angle.
      Ask FixBot
Carter Owen
181 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 37
Past 30 Days: 159
All Time: 7,424
