ASUS TUF Gaming FX505DY Back Case Replacement
    1. ASUS TUF Gaming FX505DY Back Case Replacement, Back Case: step 1, image 1 of 1
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
      • Flip the laptop so the back is facing up.
      Ask FixBot
    2. ASUS TUF Gaming FX505DY Back Case Replacement: step 2, image 1 of 2 ASUS TUF Gaming FX505DY Back Case Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
      • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
      Ask FixBot
    3. ASUS TUF Gaming FX505DY Back Case Replacement: step 3, image 1 of 2 ASUS TUF Gaming FX505DY Back Case Replacement: step 3, image 2 of 2
      • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
      • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
      Ask FixBot
    4. ASUS TUF Gaming FX505DY Back Case Replacement: step 4, image 1 of 2 ASUS TUF Gaming FX505DY Back Case Replacement: step 4, image 2 of 2
      • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
      Ask FixBot
2 other people completed this guide.
Benyamin Claxton
1,034 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 57
All Time: 2,563
