ASUS T300LA-US51T SSD Replacement
      • METHOD 1: Use a plastic pry tool to pop the back of the tablet off. Be careful the aluminum back is attached via plastic hooks.
      • METHOD 2: Access by removing the screen (suggested by Quantum Byte)
      • If like me you are unable to find a gap to detach the aluminium back from the frame so instead I tried accessing by removing the screen using a sharp tool (a metal blade such as a Stanley knife or a flat-ended spudger) as in the video (not my work).
      • Unfortunately, this is not as easy as in the video as the entire outer edge seems to be glued. Furthermore, the screen cracks v. easily. Since my screen was already damaged, I ended up breaking up and tearing the screen off. I am perhaps not best to advise on this method.
      • I suggest using a hair dryer/ heat gun to melt the glue sufficiently to make the screen detach.
      Ask FixBot
    1. ASUS T300LA-US51T SSD Replacement: step 2, image 1 of 2 ASUS T300LA-US51T SSD Replacement: step 2, image 2 of 2
      • The battery is attached via 6 screws. They are clearly marked with location and screw size.
      Ask FixBot
    2. ASUS T300LA-US51T SSD Replacement: step 3, image 1 of 1
      • The SSD is a M.2 NGFF style with a size of 80mm. The label states 3.3v 2A. If replaced with a lower power drive battery life might increase.
      • Unscrew the single screw on the end of the drive. Undo the tabs on the ribbon cable above it and take the ribbon out.
      • Remove the drive and replace with a larger new one.
      Ask FixBot
Be careful to place everything back the way that you found it.
4 other people completed this guide.
Sasa Macura
177 Reputation
2 Guides authored
1 Guide Comment
Note that this guide does not work for the Asus T300 Chi which has an eMMC solid state drive soldered directly to the motherboard - you will need an eMMC reader and skill in removing soldered components to do this. Recommend taking to a data recovery professional in this case
Quantum Byte - Reply Share
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 142
All Time: 18,515
