Introduction
Cleaning the fans on your ASUS ROG Zephyrus M15 GU205L is an essential maintenance task to ensure optimal performance and prevent overheating. Dust and debris can accumulate over time, hindering the airflow and causing the fans to work harder. Here's a step-by-step guide to help you clean the fans:
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Tool used on this step:Microfiber Cleaning Cloths$3.99
Use the microfiber cloth to wipe any surface dust off the fan fins.
