Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓If your screen is glitching or the screen goes in and out, it might be a loose display connector. Use this guide if you need to check to see if your display connector is loose.
Tools
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Once the back has been removed, locate this connection cable.
Check to see if the connector is in the pin slot; if not, locate the connector.
