ASUS ROG Strix GL503VD-DB71 Battery Replacement
    1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: step 1, image 1 of 2 ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: step 1, image 2 of 2
      • Start with flipping the laptop over so that the bottom side is facing up.
      Ask FixBot
    2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 2, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 2, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 2, image 3 of 3
      • Remove the screw for the small panel with a Phillips #1 screwdriver.
      • Use your plastic opening tool to lift up the cover to remove it.
      • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
      Ask FixBot
    3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 3, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 3, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 3, image 3 of 3
      • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
      • Use a plastic opening tool to pry the back cover off of the device.
      • Remove the back cover exposing the battery.
      Ask FixBot
    4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 4, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 4, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 4, image 3 of 3
      • Remove the single screw securing the battery with a Phillips #1 screwdriver.
      • Gently pull the battery cable from its connector on the motherboard.
      • Lift up on the battery to remove it.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 119
All Time: 6,963
