ASUS ROG Strix G15 G513 RAM Replacement
    1. ASUS ROG Strix G15 G513 RAM Replacement, RAM: step 1, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement, RAM: step 1, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement, RAM: step 1, image 3 of 3
      • Firstly prepare your laptop, your tools and your new RAM sticks
      • Unplug your laptop
      Ask FixBot
    2. ASUS ROG Strix G15 G513 RAM Replacement: step 2, image 1 of 1
      • Turn your laptop upside down
      • Start unscrewing all 10 blue and orange screws with a Philips #1 screwdriver
      • The blue and orange screws are different length
      • Unscrew the red screw always last and screw it in always first
      Ask FixBot
    3. ASUS ROG Strix G15 G513 RAM Replacement: step 3, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 3, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 3, image 3 of 3
      • Keep your screws organized, you can use some screw holders, brackets or small magnets
      Ask FixBot
    4. ASUS ROG Strix G15 G513 RAM Replacement: step 4, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 4, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 4, image 3 of 3
      • Insert a plastic guitar pick or a plastic card to start peeling the back cover off
      • Start by putting one in the bottom right corner
      • Then slowly peel until you reach bottom left and top right corners
      • Put a guitar pick in each of those corners as well
      • For more detail check the official service guide manual in the attached documents section
      Ask FixBot
    5. ASUS ROG Strix G15 G513 RAM Replacement: step 5, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 5, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 5, image 3 of 3
      • Start by peeling from the bottom right corner slowly until the entire back cover comes off
      • Rotate your laptop
      • Beware of 2 thin LED ribbon cables that are still attached
      Ask FixBot
    6. ASUS ROG Strix G15 G513 RAM Replacement: step 6, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 6, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 6, image 3 of 3
      • Now you need to unplug them
      • Start by lifting the small black part of the connector up
      • Then just pull the cable away
      Ask FixBot
    7. ASUS ROG Strix G15 G513 RAM Replacement: step 7, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 7, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 7, image 3 of 3
      • Do the same for the other cable connector
      Ask FixBot
    8. ASUS ROG Strix G15 G513 RAM Replacement: step 8, image 1 of 1
      • Now remove the back cover completely
      Ask FixBot
    9. ASUS ROG Strix G15 G513 RAM Replacement: step 9, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 9, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 9, image 3 of 3
      • Now you need to disconnect the battery
      • Locate the connector
      • Pull the top tin lock away from you as seen on image 1 vs 2
      • Then disconnect the battery connector by supporting it from sides and lifting it up
      Ask FixBot
    10. ASUS ROG Strix G15 G513 RAM Replacement: step 10, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 10, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 10, image 3 of 3
      • Rotate your laptop again
      • Locate the RAM compartment
      • The RAM may have thermal tape on top of it, if it doesn't it is not a big issue and if it does just take it off and put it on your new RAM sticks
      Ask FixBot
    11. ASUS ROG Strix G15 G513 RAM Replacement: step 11, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 11, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 11, image 3 of 3
      • You can take your current RAM out by pushing the 2 steel legs holding down your RAM outwards until the RAM "jumps out" and just gently take it out
      • Align and insert your new RAM at a 30-degree angle, push it in completely and push down on it until it clicks
      Ask FixBot
    12. ASUS ROG Strix G15 G513 RAM Replacement: step 12, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 12, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 12, image 3 of 3
      • Now reconnect the battery connector
      • Push it down and secure it with the steel latch
      Ask FixBot
    13. ASUS ROG Strix G15 G513 RAM Replacement: step 13, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 13, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 13, image 3 of 3
      • Rotate your laptop once again
      • Put the back cover against a wall so that you can reconnect the LED flex cables without the need of holding it
      Ask FixBot
    14. ASUS ROG Strix G15 G513 RAM Replacement: step 14, image 1 of 2 ASUS ROG Strix G15 G513 RAM Replacement: step 14, image 2 of 2
      • Push the left cable in until you can barely see the white line on the blue part of the cable
      • Secure it by pressing the black latch down
      Ask FixBot
    15. ASUS ROG Strix G15 G513 RAM Replacement: step 15, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 15, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 15, image 3 of 3
      • Do the same for the right cable
      Ask FixBot
    16. ASUS ROG Strix G15 G513 RAM Replacement: step 16, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 16, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 16, image 3 of 3
      • Now put the back cover back on and pat it down so that everything clicks and holds in place
      Ask FixBot
    17. ASUS ROG Strix G15 G513 RAM Replacement: step 17, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 17, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 17, image 3 of 3
      • Rotate it one last time
      • With a Philips #1 screwdriver screw the bottom right screw first
      • Then screw in the rest
      Ask FixBot
    18. ASUS ROG Strix G15 G513 RAM Replacement: step 18, image 1 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 18, image 2 of 3 ASUS ROG Strix G15 G513 RAM Replacement: step 18, image 3 of 3
      • Now plug in your laptop
      • Power it on and check in BIOS or task manager if your RAM is set up correctly
      • Beware of Memory training (check out conclusion)
      Ask FixBot
Hopefully your RAM replacement was successful, don't forget to double-check for example in BIOS or the Task manager -> Performance -> Memory tab. Also upon first boot with your new RAM a strange occurrence may happen where the laptop starts turning itself on and off while the screen stays black with no logo or anything repeatedly, don't worry this is called "memory training" the laptop is trying to figure out how much RAM it has, what frequency it runs at and what voltages it needs.... the best move is to let it be for 2 to 5 minutes. If it is taking longer than 5 minutes try doing a hard reset by holding down the power button until the laptop turns off and then manually turn it on again.
Attached Documents
Nimbyte
1,863 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 92
Past 30 Days: 311
All Time: 627
