Introduction
Go to step 1 ↓Laptops, particularly gaming laptops, are highly favored by many, due to their portability. However, gaming laptops still encounter issues related to battery durability because of heavy use and constant charging. If the battery in your ASUS ROG Strix G15 G513 has come to the end of its life cycle, follow this guide to replace it.
Before beginning this repair, power off your laptop and unplug it from the charger. If your battery is swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Asus C41N2010 Battery$69.99
Parts
Asus C41N2010 Battery$59.99
Tools
Flip the laptop over.
Use a Phillips #1 screwdriver to remove:
Four 3 mm-long PH1 screws
Three 6 mm-long PH1 screws
Two 5.5 mm-long PH1 screws
Use an opening too to gently pry the back case from the laptop.
Start from the bottom right corner and with a prying tool/guitar pick work your way to the bottom left, and top right corners then gently lift it up, and it will snap off as seen in the disassembly section in the attached Service guide document
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide. Take your e-waste to an R2 or e-Stewards certified recycler.
7 other people completed this guide.
Attached Documents
1 Guide Comment
Gran guia gracias por toda la informacion me sirvio de maravillas para el laptop
