ASUS ROG Spatha X Scroll Wheel Replacement
  1. ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: step 1, image 1 of 3 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: step 1, image 2 of 3 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: step 1, image 3 of 3
    • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
    • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
    • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
    Ask FixBot
  2. ASUS ROG Spatha X Scroll Wheel Replacement: step 2, image 1 of 2 ASUS ROG Spatha X Scroll Wheel Replacement: step 2, image 2 of 2
    • Lift the upper mouse cover up and off.
    Ask FixBot
  3. ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: step 3, image 1 of 3 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: step 3, image 2 of 3 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: step 3, image 3 of 3
    • Remove the Phillips screw securing the ribbon cable scroll wheel.
    • Disconnect the ribbon cable from the scroll wheel.
    Ask FixBot
  4. ASUS ROG Spatha X Scroll Wheel Replacement: step 4, image 1 of 3 ASUS ROG Spatha X Scroll Wheel Replacement: step 4, image 2 of 3 ASUS ROG Spatha X Scroll Wheel Replacement: step 4, image 3 of 3
    • There is a plastic axle holding the scroll wheel in place. It is cinched into a plastic housing unit towards the right side of the mouse (towards the pinky rest).
    • Use one hand to gently pull the housing for the axle away from the scroll wheel as you simultaneously use the other hand to pull up and away from the housing unit.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
cgrabowski1
671 Reputation
5 Guides authored
1 Guide Comment
Easy replacement but good luck finding the part. It's not sold ANYWHERE.
Tyler Pratt - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 105
All Time: 1,102
