Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓Use this guide if you are experiencing issues with the battery for the ASUS ROG Spatha X. This is a very easy replacement guide; the necessary tool should be included with your mouse in the box.
Tools
Spudger4.9
Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
Grip the white battery connector and pull it up and out of its motherboard socket.
For optimal performance, calibrate your newly installed battery after completing this guide.
