ASUS ROG Raikiri Pro Joystick Cover Replacement
  1. ASUS ROG Raikiri Pro Joystick Cover Replacement, Joystick Cover: step 1, image 1 of 3 ASUS ROG Raikiri Pro Joystick Cover Replacement, Joystick Cover: step 1, image 2 of 3 ASUS ROG Raikiri Pro Joystick Cover Replacement, Joystick Cover: step 1, image 3 of 3
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Repeat the steps to remove the right handle cover.
    • Remove the handle covers.
    Ask FixBot
  2. ASUS ROG Raikiri Pro Joystick Cover Replacement: step 2, image 1 of 3 ASUS ROG Raikiri Pro Joystick Cover Replacement: step 2, image 2 of 3 ASUS ROG Raikiri Pro Joystick Cover Replacement: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    Ask FixBot
  3. ASUS ROG Raikiri Pro Joystick Cover Replacement: step 3, image 1 of 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    Ask FixBot
  4. ASUS ROG Raikiri Pro Joystick Cover Replacement: step 4, image 1 of 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: step 4, image 2 of 2
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    Ask FixBot
  5. ASUS ROG Raikiri Pro Joystick Cover Replacement: step 5, image 1 of 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    Ask FixBot
  6. ASUS ROG Raikiri Pro Joystick Cover Replacement: step 6, image 1 of 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: step 6, image 2 of 2
    • Use a spudger to carefully remove the left board.
    Ask FixBot
  7. ASUS ROG Raikiri Pro Joystick Cover Replacement: step 7, image 1 of 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: step 7, image 2 of 2
    • Flip the board over and remove the joystick cover.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 101
All Time: 907
