ASUS ROG G750JW-RS72-CB RAM Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
105
All Time:
1,811
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The RAM is where the working memory of the computer is and replacing it will allow your computer to perform better.
Replacing the RAM is the easiest and cheapest way to help speed up a computer.
Tools
    1. ASUS ROG G750JW-RS72-CB RAM Replacement, Battery: step 1, image 1 of 1
      • Make sure you completely power down the computer before beginning this process.
      • With your finger, push this slide to the right. The battery should pop out of place.
      Ask FixBot
    2. ASUS ROG G750JW-RS72-CB RAM Replacement: step 2, image 1 of 1
      • Pull the battery out of its place gently.
      Ask FixBot
    1. ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: step 3, image 1 of 2 ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: step 3, image 2 of 2
      • Open flap in center and underneath you will find a screw, remove the 5.2mm screw with a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS ROG G750JW-RS72-CB RAM Replacement: step 4, image 1 of 2 ASUS ROG G750JW-RS72-CB RAM Replacement: step 4, image 2 of 2
      • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
      Ask FixBot
    3. ASUS ROG G750JW-RS72-CB RAM Replacement: step 5, image 1 of 1
      • This exposes two hard drive caddies.
      • This also exposes two RAM slots.
      Ask FixBot
    4. ASUS ROG G750JW-RS72-CB RAM Replacement: step 6, image 1 of 1
      • Push the metal tabs outward that are located on both sides of the top ram.
      • Remove the RAM from the slot.
      • Repeat with bottom RAM
      Ask FixBot
    5. ASUS ROG G750JW-RS72-CB RAM Replacement: step 7, image 1 of 2 ASUS ROG G750JW-RS72-CB RAM Replacement: step 7, image 2 of 2
      • Align new RAM's key with the slot.
      • Place RAM in slot at a 45 degree angle downward, until the teeth are hidden inside of the socket itself.
      • Push down on RAM until a clicking sound is heard, meaning it is in place.
      • Repeat with top RAM
      Ask FixBot
To reassemble your device, follow Steps 1-4 in reverse order.
Ellie Moran
142 Reputation
1 Guide authored
Cal Poly, Team S11-G5, Banghart Winter 2018 Member of Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Members
60 Guides authored
1 Guide Comment
What about replacing the two internal RAM Modules?
Latiron London - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 105
All Time: 1,811
