Up to 20% off select tools
ASUS ROG G46VW RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
55
All Time:
1,111
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Before removing the RAM sticks, be sure you have a clean surface to place them on as they are sensitive to dust and dirt.
    1. ASUS ROG G46VW RAM Replacement, RAM: step 1, image 1 of 2 ASUS ROG G46VW RAM Replacement, RAM: step 1, image 2 of 2
      • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS ROG G46VW RAM Replacement: step 2, image 1 of 1
      • Remove the RAM cover by lifting the screw cover and pulling away firmly.
      Ask FixBot
    3. ASUS ROG G46VW RAM Replacement: step 3, image 1 of 2 ASUS ROG G46VW RAM Replacement: step 3, image 2 of 2
      • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
      Ask FixBot
    4. ASUS ROG G46VW RAM Replacement: step 4, image 1 of 1
      • Pull out the RAM stick carefully.
      • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
      Ask FixBot
    5. ASUS ROG G46VW RAM Replacement: step 5, image 1 of 1
      • Repeat steps 3-4 to remove the second RAM stick.
      Ask FixBot
Author
with
Amon Stewart
472 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 55
All Time: 1,111
