Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓If your Asus ROG G46VW laptop is not powering on, overheating, or experiencing major hardware issues, the motherboard may need to be replaced. This guide shows you how to remove and replace the motherboard.
If you are unsure whether the motherboard is the issue, check that the battery, charger, and RAM are functioning properly before proceeding.
The motherboard is the main circuit board of the laptop and supports all its major components, including the CPU, RAM, storage, and I/O subsystems.
This repair requires disassembling several internal components and is best suited for users who are comfortable working with small electronics.
Before beginning, power off the device and disconnect it from any external power source. Take care when handling internal components to avoid damage from static electricity.
With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
Remove the 10 screws securing the motherboard using a Phillips #0 screwdriver.
3 other people completed this guide.
