Up to 20% off select tools
ASUS ROG G46VW Keyboard Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
65
All Time:
1,584
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your ASUS ROG G46VW keyboard is broken, dirty, or missing a few keys, use this guide to replace the keyboard.
The keyboard is an essential component to a computer, giving the user the assets to control the motherboard and computer itself. Without it, you will have a computer without the necessary parts to control it, given you don’t have a touchscreen. A faulty keyboard can do this, as over time keys can break, and items can get stuck in the keyboard, stopping the user from using specific letters and/or commands.
Before starting, be sure to have a screwdriver, spudger, and opening tools prepared to remove the faulty keyboard. If it is found that the keys were not working due to pieces of debris, remove or clean the debris and test your keyboard to confirm if it is still faulty or not. Once sure your keyboard is broken or faulty, be prepared to replace it with a new keyboard.
Before beginning, make sure to turn the power off to your laptop completely and disconnect from any wires, especially from your power source.
    1. ASUS ROG G46VW Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Remove the two screws from underneath the RAM cover.
      Ask FixBot
    2. ASUS ROG G46VW Keyboard Replacement: step 2, image 1 of 1
      • Remove all of the screws from the bottom of the case.
      • If replacing the screen, remove the rubber feet to reveal two more screws.
      Ask FixBot
    3. ASUS ROG G46VW Keyboard Replacement: step 3, image 1 of 1
      • Turn the laptop over and remove the screws as shown
      Ask FixBot
    4. ASUS ROG G46VW Keyboard Replacement: step 4, image 1 of 1
      • Carefully pry the keyboard away using your spudger and the opening tools.
      • Be sure not to damage the clips holding the keyboard to the bottom case.
      Ask FixBot
    5. ASUS ROG G46VW Keyboard Replacement: step 5, image 1 of 2 ASUS ROG G46VW Keyboard Replacement: step 5, image 2 of 2
      • Detach the ribbon cable by releasing the clip
      Ask FixBot
Author
with
Amon Stewart
472 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 65
All Time: 1,584
