Up to 20% off select tools
ASUS Q536F Screen Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
65
All Time:
1,031
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 50 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Parts
Tools
Introduction
Go to step 1 ↓
Our laptops screen cracked so we needed to replace it. This guide will help you in the process of replacing the display screen for ASUS Q536F. If your screen is damaged in any way, for example, cracked screen, pixels not properly displayed, not displaying vivid colors, or just simple damage being seen, then the entire screen needs to be replaced.
In the process of replacing the screen, take extra precaution, as you are working with a screen and it can shatter. Make sure you take time to wear equipment such as safety glasses. This simple-to-follow tutorial will help users prolong the life of their laptops and replace the screen. Make sure to have the laptop unplugged and powered off before proceeding.
    1. ASUS Q536F Screen Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F Screen Replacement, Back Panel: step 1, image 2 of 2
      • Remove ten 2 mm screws using a Phillips #0 screwdriver.
      • Remove the screw in the center using a T4 Torx screwdriver.
      • Use an iFixit opening tool to pry open the back panel.
      • It's normal to hear some cracking, but proceed with caution.
      Ask FixBot
    1. ASUS Q536F Screen Replacement, Display Assembly: step 2, image 1 of 1
      • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS Q536F Screen Replacement: step 3, image 1 of 3 ASUS Q536F Screen Replacement: step 3, image 2 of 3 ASUS Q536F Screen Replacement: step 3, image 3 of 3
      • Using your fingers, unplug the two power cables connecting the display to the motherboard.
      • Remove the display assembly from the laptop.
      Ask FixBot
    1. ASUS Q536F Screen Replacement, Screen: step 4, image 1 of 3 ASUS Q536F Screen Replacement, Screen: step 4, image 2 of 3 ASUS Q536F Screen Replacement, Screen: step 4, image 3 of 3
      • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
      • Use an iOpener to help loosen the adhesive on the screen.
      • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
      • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
      Ask FixBot
    2. ASUS Q536F Screen Replacement: step 5, image 1 of 1
      • Carefully remove the screen from the rest of the display.
      • The new screen should come with the sticky adhesive.
      Ask FixBot
Author
with
Adra Ledward
557 Reputation
5 Guides authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
72 Guides authored
1 Guide Comment
I've never had to do a screen replacement but I know my way around PCs. Laptops not as much, but have done other smaller repairs. Replacing the entire screen has me quite anxious. Whats the difficulty level on that?
Acrillix Official - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 65
All Time: 1,031
