Up to 20% off select tools
ASUS Q536F SSD Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
60
All Time:
733
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Before proceeding with an SSD upgrade or replacement in a laptop, it's crucial to check compatibility with the laptop model, ensure proper backup of important data, and consider factors such as budget and specific performance requirements.
    1. ASUS Q536F SSD Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F SSD Replacement, Back Panel: step 1, image 2 of 2
      • Remove ten 2 mm screws using a Phillips #0 screwdriver.
      • Remove the screw in the center using a T4 Torx screwdriver.
      • Use an iFixit opening tool to pry open the back panel.
      • It's normal to hear some cracking, but proceed with caution.
      Ask FixBot
    1. ASUS Q536F SSD Replacement, SSD: step 2, image 1 of 1
      • Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS Q536F SSD Replacement: step 3, image 1 of 1
      • Pull the SSD out of its slot.
      Ask FixBot
To reassemble your device, Follow these instructions in reverse order.
Author
with
Adra Ledward
557 Reputation
5 Guides authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 60
All Time: 733
