Up to 20% off select tools
ASUS Q536F Motherboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
73
All Time:
977
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Parts
Tools
Introduction
Go to step 1 ↓
When replacing a motherboard, it's crucial to select a compatible replacement and consider factors like form factor, chipset, and socket type. Additionally, users should ensure they have proper technical knowledge or seek professional assistance, as motherboard replacements can be complex and may require transferring components from the old motherboard to the new one.
    1. ASUS Q536F Motherboard Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F Motherboard Replacement, Back Panel: step 1, image 2 of 2
      • Remove ten 2 mm screws using a Phillips #0 screwdriver.
      • Remove the screw in the center using a T4 Torx screwdriver.
      • Use an iFixit opening tool to pry open the back panel.
      • It's normal to hear some cracking, but proceed with caution.
      Ask FixBot
    1. ASUS Q536F Motherboard Replacement, Battery: step 2, image 1 of 2 ASUS Q536F Motherboard Replacement, Battery: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
      • Detach the battery cable from the motherboard using a pair of tweezers.
      Ask FixBot
    2. ASUS Q536F Motherboard Replacement: step 3, image 1 of 3 ASUS Q536F Motherboard Replacement: step 3, image 2 of 3 ASUS Q536F Motherboard Replacement: step 3, image 3 of 3
      • Unhinge the fan cable using your fingers or a pair of tweezers.
      • Remove the battery from its slot.
      • There should be no resistance from any cable wiring at this point. If there happens to be resistance, make sure to double check and confirm nothing is being pulled.
      Ask FixBot
    1. ASUS Q536F Motherboard Replacement, Fan: step 4, image 1 of 2 ASUS Q536F Motherboard Replacement, Fan: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
      • Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
      • Warped Screw
      • Heatsink shown has warped screw, so unable to remove
      Ask FixBot
    2. ASUS Q536F Motherboard Replacement: step 5, image 1 of 1
      Buy
      • Disconnect white and black antennae cables.
      • Using tweezers for this would be helpful.
      Ask FixBot
    3. ASUS Q536F Motherboard Replacement: step 6, image 1 of 2 ASUS Q536F Motherboard Replacement: step 6, image 2 of 2
      • Disconnect fan cables pulling outwards as shown.
      Ask FixBot
    4. ASUS Q536F Motherboard Replacement: step 7, image 1 of 3 ASUS Q536F Motherboard Replacement: step 7, image 2 of 3 ASUS Q536F Motherboard Replacement: step 7, image 3 of 3
      • Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
      • The fan can be removed without removing the heatsink, although it may be easier to remove.
      Ask FixBot
    1. ASUS Q536F Motherboard Replacement, Hard Drive: step 8, image 1 of 2 ASUS Q536F Motherboard Replacement, Hard Drive: step 8, image 2 of 2
      • Disconnect the white ribbon cable from the connection lever using a Jimmy.
      Ask FixBot
    2. ASUS Q536F Motherboard Replacement: step 9, image 1 of 2 ASUS Q536F Motherboard Replacement: step 9, image 2 of 2
      • Using the Jimmy, lift the hard drive out of its slot.
      Ask FixBot
    1. ASUS Q536F Motherboard Replacement, SSD: step 10, image 1 of 1
      • Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS Q536F Motherboard Replacement: step 11, image 1 of 1
      • Pull the SSD out of its slot.
      Ask FixBot
    1. ASUS Q536F Motherboard Replacement, Motherboard: step 12, image 1 of 2 ASUS Q536F Motherboard Replacement, Motherboard: step 12, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 2 mm screws that secure the motherboard.
      Ask FixBot
    2. ASUS Q536F Motherboard Replacement: step 13, image 1 of 1
      • Using a Jimmy, pull up on the power cable.
      Ask FixBot
    3. ASUS Q536F Motherboard Replacement: step 14, image 1 of 3 ASUS Q536F Motherboard Replacement: step 14, image 2 of 3 ASUS Q536F Motherboard Replacement: step 14, image 3 of 3
      • Using the Jimmy, lift up on both ribbon cable clamps, releasing the connection point, just like in step 8.
      Ask FixBot
Author
with
Adra Ledward
557 Reputation
5 Guides authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 73
All Time: 977
