Up to 20% off select tools
ASUS Q536F Battery Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
110
All Time:
3,426
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Our Asus Q536F laptop's present battery has to be replaced and fixed, therefore here is our guide. Your laptop battery will eventually run out of power no matter how well you take care of it. Many last for several years, but ultimately they begin to deteriorate because of things like wear and tear, exposure to intense heat, and even inactivity. This simple-to-follow tutorial will help users prolong the life of their laptops and replace their outdated computer batteries for less money.
Age, damage to the battery charger, or a problem with your laptop's DC connector could all be contributing factors to the battery's poor performance in holding a charge. Make sure the wires are clean and the battery is appropriate for the particular gadget you are using.
Make sure to have the laptop unplugged and powered off before proceeding.
    1. ASUS Q536F Battery Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F Battery Replacement, Back Panel: step 1, image 2 of 2
      • Remove ten 2 mm screws using a Phillips #0 screwdriver.
      • Remove the screw in the center using a T4 Torx screwdriver.
      • Use an iFixit opening tool to pry open the back panel.
      • It's normal to hear some cracking, but proceed with caution.
      Ask FixBot
    1. ASUS Q536F Battery Replacement, Battery: step 2, image 1 of 2 ASUS Q536F Battery Replacement, Battery: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
      • Detach the battery cable from the motherboard using a pair of tweezers.
      Ask FixBot
    2. ASUS Q536F Battery Replacement: step 3, image 1 of 3 ASUS Q536F Battery Replacement: step 3, image 2 of 3 ASUS Q536F Battery Replacement: step 3, image 3 of 3
      • Unhinge the fan cable using your fingers or a pair of tweezers.
      • Remove the battery from its slot.
      • There should be no resistance from any cable wiring at this point. If there happens to be resistance, make sure to double check and confirm nothing is being pulled.
      Ask FixBot
2 other people completed this guide.
Author
with
vanessa galvez
109 Reputation
1 Guide authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
72 Guides authored
1 Guide Comment
Thank you so much!
Vincent - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 110
All Time: 3,426
