ASUS Q524U Hard Drive Replacement
    1. ASUS Q524U Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
      Ask FixBot
    2. ASUS Q524U Hard Drive Replacement: step 2, image 1 of 3 ASUS Q524U Hard Drive Replacement: step 2, image 2 of 3 ASUS Q524U Hard Drive Replacement: step 2, image 3 of 3
      • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
      Ask FixBot
    3. ASUS Q524U Hard Drive Replacement: step 3, image 1 of 1
      • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
      Ask FixBot
    4. ASUS Q524U Hard Drive Replacement: step 4, image 1 of 1
      • Remove the back panel, exposing the motherboard.
      • Set the panel aside, skin up to avoid scratches.
      Ask FixBot
    5. ASUS Q524U Hard Drive Replacement: step 5, image 1 of 1
      • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
      • The hard-drive is located in the bottom left corner of the motherboard.
      Ask FixBot
    6. ASUS Q524U Hard Drive Replacement: step 6, image 1 of 2 ASUS Q524U Hard Drive Replacement: step 6, image 2 of 2
      • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
      Ask FixBot
Finish Line
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 77
All Time: 4,557
