ASUS Q400A-BHI7N03 Screen Replacement
    1. ASUS Q400A-BHI7N03 Screen Replacement, Screen: step 1, image 1 of 1
      • Flip the laptop on its back side with the battery facing toward you.
      • Slide the tabs with lock/unlock symbol, to the unlock position.
      • Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
      Ask FixBot
    2. ASUS Q400A-BHI7N03 Screen Replacement: step 2, image 1 of 1
      • Lift the two black plastic circles off the screen using the plastic spudger.
      • Unscrew the two 8mm Phillips #0 screws.
      Ask FixBot
    3. ASUS Q400A-BHI7N03 Screen Replacement: step 3, image 1 of 1
      • Pry the front edges of the screen using the spudger.
      Ask FixBot
    4. ASUS Q400A-BHI7N03 Screen Replacement: step 4, image 1 of 1
      • Remove the four black 8mm Phillips #0 screws and set them aside.
      Ask FixBot
    5. ASUS Q400A-BHI7N03 Screen Replacement: step 5, image 1 of 1
      • Pry the LCD from the front frame.
      Ask FixBot
    6. ASUS Q400A-BHI7N03 Screen Replacement: step 6, image 1 of 1
      • Pull the gold ribbon cable to disconnect the screen from the laptop.
      Ask FixBot
3 other people completed this guide.
Wan Ahmad Aiman
403 Reputation
2 Guides authored
IUPUI, Team S1-G3, Harley Fall 2018 Member of IUPUI, Team S1-G3, Harley Fall 2018
IUPUI-HARLEY-F18S1G3
3 Members
24 Guides authored
1 Guide Comment
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
Daniel Ventura Avalos - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 884
