ASUS Q400A-BHI7N03 Optical Drive Replacement
    1. ASUS Q400A-BHI7N03 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Turn off the laptop.
      • Disconnect the charging cable from the laptop.
      • Failure to unplug the cable could result in electric shock.
      • Flip the laptop over so that it is upside down.
      • The slightly raised area is the battery.
      • Orient the laptop so that the battery is away from you.
      Ask FixBot
    2. ASUS Q400A-BHI7N03 Optical Drive Replacement: step 2, image 1 of 1
      • In the top right corner, push the tab to the right to the unlocked position.
      Ask FixBot
    3. ASUS Q400A-BHI7N03 Optical Drive Replacement: step 3, image 1 of 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: step 3, image 2 of 2
      • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
      • While holding this tab in the unlocked position, gently pull the battery away from you.
      Ask FixBot
    1. ASUS Q400A-BHI7N03 Optical Drive Replacement, Optical Drive: step 4, image 1 of 1
      • Locate and remove the 8mm PH0 screw near the middle of the laptop.
      Ask FixBot
    2. ASUS Q400A-BHI7N03 Optical Drive Replacement: step 5, image 1 of 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: step 5, image 2 of 2
      • Use a metal opening tool to remove the L-shaped, plastic cover.
      • To avoid breaking the plastic, alternate the sides where you pry.
      Ask FixBot
    3. ASUS Q400A-BHI7N03 Optical Drive Replacement: step 6, image 1 of 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: step 6, image 2 of 2
      • On the left side of the section, there is a metal tab. Using a metal opening tool, push the tab as far as possible to the left.
      • Only push on the metal tab so you do not damage the surrounding plastic.
      • Once the optical drive is sticking out of the left side of the laptop, slide it smoothly out of its slot.
      Ask FixBot
Matthew Gold
401 Reputation
4 Guides authored
UC Davis, Team 1-4, Rodger Winter 2017 Member of UC Davis, Team 1-4, Rodger Winter 2017
UCD-RODGER-W17S1G4
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 823
