ASUS Q302L Motherboard Replacement
    1. ASUS Q302L Motherboard Replacement, Back Case: step 1, image 1 of 1
      • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
      • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
      Ask FixBot
    2. ASUS Q302L Motherboard Replacement: step 2, image 1 of 3 ASUS Q302L Motherboard Replacement: step 2, image 2 of 3 ASUS Q302L Motherboard Replacement: step 2, image 3 of 3
      • Wedge a plastic opening tool under the rear case near the hinge.
      • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
      Ask FixBot
    3. ASUS Q302L Motherboard Replacement: step 3, image 1 of 1
      • Once the cover is free from all the clips, remove the cover from the laptop.
      Ask FixBot
    1. ASUS Q302L Motherboard Replacement, Battery: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
      Ask FixBot
    2. ASUS Q302L Motherboard Replacement: step 5, image 1 of 3 ASUS Q302L Motherboard Replacement: step 5, image 2 of 3 ASUS Q302L Motherboard Replacement: step 5, image 3 of 3
      • Gently wedge a plastic opening tool under the connector.
      • Pry only on the connector not the socket itself or you risk damage to the motherboard.
      • Carefully lift the connector up away from the socket to disconnect it.
      Ask FixBot
    3. ASUS Q302L Motherboard Replacement: step 6, image 1 of 2 ASUS Q302L Motherboard Replacement: step 6, image 2 of 2
      • Once the screws and connector are removed, simply pull out the battery from its place.
      Ask FixBot
    1. ASUS Q302L Motherboard Replacement, Fan: step 7, image 1 of 2 ASUS Q302L Motherboard Replacement, Fan: step 7, image 2 of 2
      • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
      • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
      Ask FixBot
    2. ASUS Q302L Motherboard Replacement: step 8, image 1 of 3 ASUS Q302L Motherboard Replacement: step 8, image 2 of 3 ASUS Q302L Motherboard Replacement: step 8, image 3 of 3
      • Gently wedge two plastic prying tools on both sides of the black part of the connector.
      • Carefully pull out the connector from its socket.
      Ask FixBot
    3. ASUS Q302L Motherboard Replacement: step 9, image 1 of 2 ASUS Q302L Motherboard Replacement: step 9, image 2 of 2
      • Once all screws and the connector are removed, you can safely pull the fan out of its place.
      Ask FixBot
    1. ASUS Q302L Motherboard Replacement, Motherboard: step 10, image 1 of 3 ASUS Q302L Motherboard Replacement, Motherboard: step 10, image 2 of 3 ASUS Q302L Motherboard Replacement, Motherboard: step 10, image 3 of 3
      • Peel back the adhered strip to expose the black and white connections.
      • Pop the connections off the fixtures.
      Ask FixBot
    2. ASUS Q302L Motherboard Replacement: step 11, image 1 of 2 ASUS Q302L Motherboard Replacement: step 11, image 2 of 2
      • Grasp the plastic tab of each connector with your fingers.
      • Firmly pull up, releasing the connectors one at a time.
      Ask FixBot
    3. ASUS Q302L Motherboard Replacement: step 12, image 1 of 2 ASUS Q302L Motherboard Replacement: step 12, image 2 of 2
      • As in Step 8, gently pry out both sides of the white connector and pull out the connector.
      Ask FixBot
    4. ASUS Q302L Motherboard Replacement: step 13, image 1 of 3 ASUS Q302L Motherboard Replacement: step 13, image 2 of 3 ASUS Q302L Motherboard Replacement: step 13, image 3 of 3
      • For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab.
      • Gently apply upward pressure evenly across the length of the tab.
      • Once the tab has snapped backwards, remove the blue ribbon.
      Ask FixBot
    5. ASUS Q302L Motherboard Replacement: step 14, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the ten 4mm screws.
      Ask FixBot
    6. ASUS Q302L Motherboard Replacement: step 15, image 1 of 2 ASUS Q302L Motherboard Replacement: step 15, image 2 of 2
      • Lift the Hinge gently up.
      • Lightly grasp the motherboard.
      • Lift the marked corner of the board first, then slide the corner of the board out from under the back corner of the case.
      • Place new thermal paste beneath the heatsink on the new motherboard.
      Ask FixBot
2 other people completed this guide.
Nicholas Lozier
302 Reputation
2 Guides authored
IUPUI, Team S2-G4, Harley Spring 2019 Member of IUPUI, Team S2-G4, Harley Spring 2019
IUPUI-HARLEY-S19S2G4
3 Members
24 Guides authored
1 Guide Comment
Where can I get a replacement motherboard?
Alex - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 58
All Time: 1,996
