Up to 20% off select tools
ASUS Q302L Fan Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
86
All Time:
1,450
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will take you through the steps of replacing a cooling fan that is no longer working.
    1. ASUS Q302L Fan Replacement, Back Case: step 1, image 1 of 1
      • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
      • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
      Ask FixBot
    2. ASUS Q302L Fan Replacement: step 2, image 1 of 3 ASUS Q302L Fan Replacement: step 2, image 2 of 3 ASUS Q302L Fan Replacement: step 2, image 3 of 3
      • Wedge a plastic opening tool under the rear case near the hinge.
      • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
      Ask FixBot
    3. ASUS Q302L Fan Replacement: step 3, image 1 of 1
      • Once the cover is free from all the clips, remove the cover from the laptop.
      Ask FixBot
    1. ASUS Q302L Fan Replacement, Fan: step 4, image 1 of 2 ASUS Q302L Fan Replacement, Fan: step 4, image 2 of 2
      • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
      • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
      Ask FixBot
    2. ASUS Q302L Fan Replacement: step 5, image 1 of 3 ASUS Q302L Fan Replacement: step 5, image 2 of 3 ASUS Q302L Fan Replacement: step 5, image 3 of 3
      • Gently wedge two plastic prying tools on both sides of the black part of the connector.
      • Carefully pull out the connector from its socket.
      Ask FixBot
    3. ASUS Q302L Fan Replacement: step 6, image 1 of 2 ASUS Q302L Fan Replacement: step 6, image 2 of 2
      • Once all screws and the connector are removed, you can safely pull the fan out of its place.
      Ask FixBot
Author
with
Kerolus Gerges
231 Reputation
2 Guides authored
USF Tampa, Team S13-G4, Cagle Spring 2017 Member of USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 86
All Time: 1,450
