Up to 20% off select tools
ASUS Q302L Battery Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
128
All Time:
7,110
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will take you through the steps of replacing your faulty battery on your ASUS Q302L.
    1. ASUS Q302L Battery Replacement, Back Case: step 1, image 1 of 1
      • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
      • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
      Ask FixBot
    2. ASUS Q302L Battery Replacement: step 2, image 1 of 3 ASUS Q302L Battery Replacement: step 2, image 2 of 3 ASUS Q302L Battery Replacement: step 2, image 3 of 3
      • Wedge a plastic opening tool under the rear case near the hinge.
      • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
      Ask FixBot
    3. ASUS Q302L Battery Replacement: step 3, image 1 of 1
      • Once the cover is free from all the clips, remove the cover from the laptop.
      Ask FixBot
    1. ASUS Q302L Battery Replacement, Battery: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
      Ask FixBot
    2. ASUS Q302L Battery Replacement: step 5, image 1 of 3 ASUS Q302L Battery Replacement: step 5, image 2 of 3 ASUS Q302L Battery Replacement: step 5, image 3 of 3
      • Gently wedge a plastic opening tool under the connector.
      • Pry only on the connector not the socket itself or you risk damage to the motherboard.
      • Carefully lift the connector up away from the socket to disconnect it.
      Ask FixBot
    3. ASUS Q302L Battery Replacement: step 6, image 1 of 2 ASUS Q302L Battery Replacement: step 6, image 2 of 2
      • Once the screws and connector are removed, simply pull out the battery from its place.
      Ask FixBot
3 other people completed this guide.
Author
with
khalifa
110 Reputation
1 Guide authored
USF Tampa, Team S13-G4, Cagle Spring 2017 Member of USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 128
All Time: 7,110
