ASUS Padfone X mini Station Battery Replacement
    1. ASUS Padfone X mini Station Battery Replacement, Battery: step 1, image 1 of 1
      • Insert the plastic opening tool between the edge of the screen and the back cover.
      • Gently pry them apart. Use hands to pull them apart if necessary.
      Ask FixBot
    2. ASUS Padfone X mini Station Battery Replacement: step 2, image 1 of 2 ASUS Padfone X mini Station Battery Replacement: step 2, image 2 of 2
      • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
      Ask FixBot
    3. ASUS Padfone X mini Station Battery Replacement: step 3, image 1 of 3 ASUS Padfone X mini Station Battery Replacement: step 3, image 2 of 3 ASUS Padfone X mini Station Battery Replacement: step 3, image 3 of 3
      • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
      • Using the opening tools, pry the battery off of the adhesive.
      • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
      Ask FixBot
Alexzander Pastore
389 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 40
All Time: 859
