ASUS PadFone X Vibration Motor Replacement
    1. ASUS PadFone X Vibration Motor Replacement, Vibration Motor: step 1, image 1 of 2 ASUS PadFone X Vibration Motor Replacement, Vibration Motor: step 1, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose.
      Ask FixBot
    2. ASUS PadFone X Vibration Motor Replacement: step 2, image 1 of 2 ASUS PadFone X Vibration Motor Replacement: step 2, image 2 of 2
      • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
      Ask FixBot
    3. ASUS PadFone X Vibration Motor Replacement: step 3, image 1 of 2 ASUS PadFone X Vibration Motor Replacement: step 3, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
      Ask FixBot
    4. ASUS PadFone X Vibration Motor Replacement: step 4, image 1 of 1
      • Using a spudger, pry the vibration motor connector from the motherboard.
      Ask FixBot
    5. ASUS PadFone X Vibration Motor Replacement: step 5, image 1 of 1
      • Gently pry the vibration motor upwards using the spudger.
      • The vibration motor is held down by some adhesive, force might be needed to remove it.
      Ask FixBot
Ryan
223 Reputation
2 Guides authored
USF Tampa, Team 8-4, Leahy Fall 2014 Member of USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Members
60 Guides authored
1 Guide Comment
That is not the speaker, that is the motor for the vibrate functions...
The speaker is located in the plastic back of the housing near the camera hole.
tee1331 - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 95
All Time: 1,713
