ASUS PadFone X Speaker Replacement
    1. ASUS PadFone X Speaker Replacement, Speaker: step 1, image 1 of 2 ASUS PadFone X Speaker Replacement, Speaker: step 1, image 2 of 2
      • Pry off the back cover with the blue plastic opening tool. This may require a bit of force.
      Ask FixBot
    2. ASUS PadFone X Speaker Replacement: step 2, image 1 of 2 ASUS PadFone X Speaker Replacement: step 2, image 2 of 2
      • Remove the thirteen 3.6mm screws using the T5 Torx Screwdriver.
      Ask FixBot
    3. ASUS PadFone X Speaker Replacement: step 3, image 1 of 1
      • Once the screws are removed, the mid-frame can be lifted off of the phone. The speaker is on the mid-frame.
      Ask FixBot
    4. ASUS PadFone X Speaker Replacement: step 4, image 1 of 2 ASUS PadFone X Speaker Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to pry out the speaker. It should come out fairly easily.
      • Pick the speaker up and out of the mid-frame.
      Ask FixBot
William Beale
104 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2017 Member of IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 106
All Time: 704
