ASUS PadFone X Rear Facing Camera Replacement
    1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: step 1, image 1 of 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: step 1, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
      • Work your way around the phone until the entire back cover is loose.
      Ask FixBot
    2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: step 2, image 1 of 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: step 2, image 2 of 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: step 2, image 3 of 3
      • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
      Ask FixBot
    3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: step 3, image 1 of 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: step 3, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
      Ask FixBot
    4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: step 4, image 1 of 1
      • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
      • Applying too much force may damage the connector.
      Ask FixBot
    5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers, remove the rear camera from the Padfone X.
      • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
      Ask FixBot
    6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: step 6, image 1 of 1
      • Once the camera has been pulled out, replace the old camera with a new camera.
      Ask FixBot
nestor
101 Reputation
1 Guide authored
USF Tampa, Team 8-4, Leahy Fall 2014 Member of USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 107
All Time: 997
