ASUS PadFone X Rear Case Replacement
    1. ASUS PadFone X Rear Case Replacement, Remove the back panel.: step 1, image 1 of 2 ASUS PadFone X Rear Case Replacement, Remove the back panel.: step 1, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose.
      Ask FixBot
    2. ASUS PadFone X Rear Case Replacement, Antenna replacement: step 2, image 1 of 1
      • Replace the back cover with the new one; the antenna is integrated with the back panel.
      Ask FixBot
John Kue
379 Reputation
2 Guides authored
USF Tampa, Team 8-4, Leahy Fall 2014 Member of USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 110
All Time: 1,429
