ASUS PadFone X Motherboard Replacement
    1. ASUS PadFone X Motherboard Replacement, Motherboard: step 1, image 1 of 2 ASUS PadFone X Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose.
      Ask FixBot
    2. ASUS PadFone X Motherboard Replacement: step 2, image 1 of 2 ASUS PadFone X Motherboard Replacement: step 2, image 2 of 2
      • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
      Ask FixBot
    3. ASUS PadFone X Motherboard Replacement: step 3, image 1 of 2 ASUS PadFone X Motherboard Replacement: step 3, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
      Ask FixBot
    4. ASUS PadFone X Motherboard Replacement: step 4, image 1 of 1
      • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
      • Applying too much force will damage the connector.
      Ask FixBot
    5. ASUS PadFone X Motherboard Replacement: step 5, image 1 of 2 ASUS PadFone X Motherboard Replacement: step 5, image 2 of 2
      • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
      • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
      Ask FixBot
    6. ASUS PadFone X Motherboard Replacement: step 6, image 1 of 1
      • Using a spudger, pry the vibration motor connector from the motherboard.
      Ask FixBot
    7. ASUS PadFone X Motherboard Replacement: step 7, image 1 of 1
      • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
      • Applying too much force will damage the conector
      Ask FixBot
    8. ASUS PadFone X Motherboard Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers, remove the rear camera from the Padfone X.
      • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
      Ask FixBot
    9. ASUS PadFone X Motherboard Replacement: step 9, image 1 of 2 ASUS PadFone X Motherboard Replacement: step 9, image 2 of 2
      • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
      • Do this for all the clips holding the panel down.
      • After all clips are bent away, remove the panel.
      Ask FixBot
    10. ASUS PadFone X Motherboard Replacement: step 10, image 1 of 2 ASUS PadFone X Motherboard Replacement: step 10, image 2 of 2
      • Disconnect the first connector by prying it upward using the blue plastic opening tool.
      • Disconnect the second connector by first lifting the lock then pulling the connector outward.
      Ask FixBot
    11. ASUS PadFone X Motherboard Replacement: step 11, image 1 of 3 ASUS PadFone X Motherboard Replacement: step 11, image 2 of 3 ASUS PadFone X Motherboard Replacement: step 11, image 3 of 3
      • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
      • Work your way around until the motherboard is free.
      Ask FixBot
    12. ASUS PadFone X Motherboard Replacement: step 12, image 1 of 1
      • Flip the motherboard over and locate the front facing camera.
      • Using the tweezers gently remove the black locking mechanism.
      • The black locking mechanism is very fragile and extreme care should be exercised during removal.
      Ask FixBot
    13. ASUS PadFone X Motherboard Replacement: step 13, image 1 of 2 ASUS PadFone X Motherboard Replacement: step 13, image 2 of 2
      • Use the tweezers to gently pull on the connector to remove the camera.
      Ask FixBot
Ryan
223 Reputation
2 Guides authored
USF Tampa, Team 8-4, Leahy Fall 2014 Member of USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Members
60 Guides authored
4 Guide Comments
There is a step missing between step 10 and 11, you didn't explain how to remove the flexible connector that go's to the power/volume buttons next to the camera location on the side of the phone.
David Baxter - Reply Share
which I only had to gently pry up on the connector from the center of the phone out and it came right off.
Hey iFixits,
I have a Padfone S (international version, supposedly the same as the Padfone X sold in the states), which suffered water damage. I presume the logic board needs replacing and since there are more Padfone X's out there, thinking of buying a 'for parts' phone with say, a broken screen, and just swapping logic boards to make one working phone. Does anyone know if these logic boards for the S and X are compatible?? Thanks in advance.
Jack - Reply Share
I have Asus padfone 2 the phones motherboard is damaged how to use the pad
tushar.modak - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 2,455
