Up to 20% off select tools
ASUS PadFone X Battery Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
94
All Time:
5,829
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Replace the battery from your PadFone X.
    1. ASUS PadFone X Battery Replacement, Remove the back panel.: step 1, image 1 of 2 ASUS PadFone X Battery Replacement, Remove the back panel.: step 1, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose.
      Ask FixBot
    2. ASUS PadFone X Battery Replacement, Remove the screws.: step 2, image 1 of 2 ASUS PadFone X Battery Replacement, Remove the screws.: step 2, image 2 of 2
      • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
      Ask FixBot
    3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: step 3, image 1 of 2 ASUS PadFone X Battery Replacement, Remove the Mid-Frame: step 3, image 2 of 2
      • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
      Ask FixBot
    4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: step 4, image 1 of 2 ASUS PadFone X Battery Replacement, Remove the Battery Connector: step 4, image 2 of 2
      • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
      • Applying too much force may damage the connector.
      Ask FixBot
    5. ASUS PadFone X Battery Replacement, Remove the battery.: step 5, image 1 of 2 ASUS PadFone X Battery Replacement, Remove the battery.: step 5, image 2 of 2
      • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
      • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
      Ask FixBot
4 other people completed this guide.
Author
with
John Kue
379 Reputation
2 Guides authored
USF Tampa, Team 8-4, Leahy Fall 2014 Member of USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 94
All Time: 5,829
