This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the hard drive and/or RAM of an Asus P452LA by opening the housing from the bottom.
Unscrew the 8 screws on the back of the device
Remove the battery by pushing the two sliders to the unlocked position
Unscrew the 2 screws that were hidden by the battery
Prepare a support (cardboard, a stack of books, etc.) to prop up the bottom of the computer (there is a cable)
Find the opening line of the case (look around the ports)
Pre-open the case using the opening tools and/or an opening pick along this line
Open carefully and prop the bottom of the computer against the support so as not to damage the cable
Locate the hard drive's position (pink box)
Unscrew the 2 screws on the hard drive bracket
Note: the RAM is located in the green box. If you want to replace it, you can unlock it using the two ejector tabs on the side.
Unscrew the 4 screws from the hard drive tray
Gently spread the edges to remove the existing hard drive
Replace with the new hard drive
To reassemble your device, follow the instructions in reverse order.
