Up to 20% off select tools
ASUS N56JR-MH71 RAM Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
15
Past 30 Days:
68
All Time:
875
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 50 seconds
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you want to upgrade memory, this guide will show you how to replace the RAM. Be sure the type of RAM used is DDR3L SDRAM.
    1. ASUS N56JR-MH71 RAM Replacement, Battery: step 1, image 1 of 2 ASUS N56JR-MH71 RAM Replacement, Battery: step 1, image 2 of 2
      • Push the battery latch.
      Ask FixBot
    2. ASUS N56JR-MH71 RAM Replacement: step 2, image 1 of 1
      • Keep the battery latch held while you remove the battery.
      Ask FixBot
    1. ASUS N56JR-MH71 RAM Replacement, RAM: step 3, image 1 of 3 ASUS N56JR-MH71 RAM Replacement, RAM: step 3, image 2 of 3 ASUS N56JR-MH71 RAM Replacement, RAM: step 3, image 3 of 3
      • Remove the one screw securing the back cover.
      • Pry off the cover using a finger.
      • This device was missing its screws on the back cover when we received the device. As a result, we do not know what head type the screws are, along with their lengths.
      Ask FixBot
    2. ASUS N56JR-MH71 RAM Replacement: step 4, image 1 of 2 ASUS N56JR-MH71 RAM Replacement: step 4, image 2 of 2
      • Push the clips outwards using two fingers.
      • Lift the RAM to remove it from the slot.
      • Repeat step 4 for the second RAM slot.
      Ask FixBot
Author
with
Ruben Lopez
399 Reputation
4 Guides authored
IUPUI, Team S1-G4, Baechle Fall 2018 Member of IUPUI, Team S1-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 68
All Time: 875
