ASUS N550JK-DS71T Laptop RAM stick Replacement
    1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: step 1, image 1 of 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: step 1, image 2 of 2
      • Turn the laptop off and unplug all cables.
      • Flip over so the bottom is facing you.
      • Remove the ten 3mm Torx T5 screws from the bottom cover.
      Ask FixBot
    2. ASUS N550JK-DS71T Laptop RAM stick Replacement: step 2, image 1 of 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: step 2, image 2 of 2
      • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
      • Run the spudger along the perimeter of the bottom cover to remove.
      Ask FixBot
    1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: step 3, image 1 of 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: step 3, image 2 of 2
      • Remove the three 4mm JIS #0 screws from the battery.
      Ask FixBot
    2. ASUS N550JK-DS71T Laptop RAM stick Replacement: step 4, image 1 of 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: step 4, image 2 of 2
      • Using both hands, lift the battery vertically out of the device.
      Ask FixBot
    1. ASUS N550JK-DS71T Laptop RAM stick Replacement, RAM Stick: step 5, image 1 of 1
      • Put on anti-static wristband and attach clip-end to any metal screw insert.
      • The wristband is recommended when working closely with circuit boards due to potential static discharge.
      Ask FixBot
    2. ASUS N550JK-DS71T Laptop RAM stick Replacement: step 6, image 1 of 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: step 6, image 2 of 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: step 6, image 3 of 3
      • The RAM will be secured by two metal clips surrounded by white plastic.
      • Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
      Ask FixBot
Steven Hahn
899 Reputation
6 Guides authored
USF Tampa, Team S5-G1, Passmore Spring 2018 Member of USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 37
All Time: 1,568
