ASUS N550JK-DS71T Laptop Back Case Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
87
All Time:
2,475
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will detail how to remove and replace the back case of the device. This will give you access to the inner parts of the laptop.
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
    1. ASUS N550JK-DS71T Laptop Back Case Replacement, Back Case: step 1, image 1 of 2 ASUS N550JK-DS71T Laptop Back Case Replacement, Back Case: step 1, image 2 of 2
      • Turn the laptop off and unplug all cables.
      • Flip over so the bottom is facing you.
      • Remove the ten 3mm Torx T5 screws from the bottom cover.
      Ask FixBot
    2. ASUS N550JK-DS71T Laptop Back Case Replacement: step 2, image 1 of 2 ASUS N550JK-DS71T Laptop Back Case Replacement: step 2, image 2 of 2
      • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
      • Run the spudger along the perimeter of the bottom cover to remove.
      Ask FixBot
5 other people completed this guide.
Steven Hahn
899 Reputation
6 Guides authored
USF Tampa, Team S5-G1, Passmore Spring 2018 Member of USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 87
All Time: 2,475
