ASUS K53E-BBR1 RAM Replacement
    1. ASUS K53E-BBR1 RAM Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over so you can see the battery.
      Ask FixBot
    2. ASUS K53E-BBR1 RAM Replacement: step 2, image 1 of 1
      • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
      Ask FixBot
    3. ASUS K53E-BBR1 RAM Replacement: step 3, image 1 of 3 ASUS K53E-BBR1 RAM Replacement: step 3, image 2 of 3 ASUS K53E-BBR1 RAM Replacement: step 3, image 3 of 3
      • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
      Ask FixBot
    1. ASUS K53E-BBR1 RAM Replacement, RAM: step 4, image 1 of 2 ASUS K53E-BBR1 RAM Replacement, RAM: step 4, image 2 of 2
      • Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
      Ask FixBot
    2. ASUS K53E-BBR1 RAM Replacement: step 5, image 1 of 2 ASUS K53E-BBR1 RAM Replacement: step 5, image 2 of 2
      • Slide the back panel backwards until it stops.
      • You can now lift the panel up and out of the laptop casing.
      Ask FixBot
    3. ASUS K53E-BBR1 RAM Replacement: step 6, image 1 of 3 ASUS K53E-BBR1 RAM Replacement: step 6, image 2 of 3 ASUS K53E-BBR1 RAM Replacement: step 6, image 3 of 3
      • The RAM is now visible.
      • Remove the RAM by pressing out on both tabs visible on each side of the RAM.
      • To work the tabs, take your finger tips and press outwards from the indents on the RAM.
      Ask FixBot
    4. ASUS K53E-BBR1 RAM Replacement: step 7, image 1 of 2 ASUS K53E-BBR1 RAM Replacement: step 7, image 2 of 2
      • The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
      • Gently Pull the RAM out of its connector without pushing down or pulling up.
      Ask FixBot
    5. ASUS K53E-BBR1 RAM Replacement: step 8, image 1 of 3 ASUS K53E-BBR1 RAM Replacement: step 8, image 2 of 3 ASUS K53E-BBR1 RAM Replacement: step 8, image 3 of 3
      • Repeat the previous two steps for the second stick of RAM.
      Ask FixBot
William Colangelo
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 64
All Time: 617
