ASUS K200MA-DS01T Hard Drive Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
70
All Time:
967
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will help to assist in replacing the hard drive for an Asus K200MA laptop.
Tools
    1. ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: step 1, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: step 1, image 2 of 2
      • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
      • Six 4mm Phillips screws using a Phillips #0 screwdriver.
      • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS K200MA-DS01T Hard Drive Replacement: step 2, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement: step 2, image 2 of 2
      • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
      Ask FixBot
    3. ASUS K200MA-DS01T Hard Drive Replacement: step 3, image 1 of 1
      • Remove the following screws:
      • Two 4mm Phillips screws using a Phillips #0 screwdriver.
      Ask FixBot
    4. ASUS K200MA-DS01T Hard Drive Replacement: step 4, image 1 of 3 ASUS K200MA-DS01T Hard Drive Replacement: step 4, image 2 of 3 ASUS K200MA-DS01T Hard Drive Replacement: step 4, image 3 of 3
      • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
      • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
      Ask FixBot
    1. ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: step 5, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: step 5, image 2 of 2
      • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
      • Gently pull the narrow connector away from the keyboard.
      Ask FixBot
    2. ASUS K200MA-DS01T Hard Drive Replacement: step 6, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement: step 6, image 2 of 2
      • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
      Ask FixBot
    1. ASUS K200MA-DS01T Hard Drive Replacement, Battery: step 7, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement, Battery: step 7, image 2 of 2
      • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
      • Remove the following screws from the middle and far ends of the battery:
      • Three 4mm Phillips screws using a Phillips #0 screwdriver.
      • The battery will be located closest to the screen.
      Ask FixBot
    2. ASUS K200MA-DS01T Hard Drive Replacement: step 8, image 1 of 3 ASUS K200MA-DS01T Hard Drive Replacement: step 8, image 2 of 3 ASUS K200MA-DS01T Hard Drive Replacement: step 8, image 3 of 3
      • Gripping the wider left section, lift the battery up and away from computer.
      Ask FixBot
    1. ASUS K200MA-DS01T Hard Drive Replacement, Fan: step 9, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement, Fan: step 9, image 2 of 2
      • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
      Ask FixBot
    2. ASUS K200MA-DS01T Hard Drive Replacement: step 10, image 1 of 1
      • Remove the following screws from the fan:
      • Two 4mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    3. ASUS K200MA-DS01T Hard Drive Replacement: step 11, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement: step 11, image 2 of 2
      • Firmly pull colored wires away from wire slot.
      Ask FixBot
    4. ASUS K200MA-DS01T Hard Drive Replacement: step 12, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement: step 12, image 2 of 2
      Tool used on this step:
      Buy
      • After removing both the screws and color coded wires, lift fan out of place.
      • Tools such as spudgers or tweezers may be used for fan removal.
      Ask FixBot
    1. ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: step 13, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: step 13, image 2 of 2
      • Four 4mm Phillips screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS K200MA-DS01T Hard Drive Replacement: step 14, image 1 of 2 ASUS K200MA-DS01T Hard Drive Replacement: step 14, image 2 of 2
      • Remove by sliding hard driving right and away from the computer using the tag on the right side.
      Ask FixBot
Terrinda
530 Reputation
4 Guides authored
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Member of CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 70
All Time: 967
