ASUS K200MA-DS01T Back Panel Removal
    1. ASUS K200MA-DS01T Back Panel Removal, Back Panel: step 1, image 1 of 2 ASUS K200MA-DS01T Back Panel Removal, Back Panel: step 1, image 2 of 2
      • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
      • Six 4mm Phillips screws using a Phillips #0 screwdriver.
      • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS K200MA-DS01T Back Panel Removal: step 2, image 1 of 2 ASUS K200MA-DS01T Back Panel Removal: step 2, image 2 of 2
      • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
      Ask FixBot
    3. ASUS K200MA-DS01T Back Panel Removal: step 3, image 1 of 1
      • Remove the following screws:
      • Two 4mm Phillips screws using a Phillips #0 screwdriver.
      Ask FixBot
    4. ASUS K200MA-DS01T Back Panel Removal: step 4, image 1 of 3 ASUS K200MA-DS01T Back Panel Removal: step 4, image 2 of 3 ASUS K200MA-DS01T Back Panel Removal: step 4, image 3 of 3
      • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
      • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
      Ask FixBot
Haleigh St. Paul
248 Reputation
1 Guide authored
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Member of CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 65
All Time: 603
