ASUS G73JH-BST7 SD Hard Drive Replacement
    1. ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: step 1, image 1 of 2 ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the computer over, so that the bottom is facing up.
      Ask FixBot
    2. ASUS G73JH-BST7 SD Hard Drive Replacement: step 2, image 1 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement: step 2, image 2 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement: step 2, image 3 of 3
      • Slide the two tabs away from the battery.
      • The left tab will lock, but the right tab must be held away from the battery.
      Ask FixBot
    3. ASUS G73JH-BST7 SD Hard Drive Replacement: step 3, image 1 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement: step 3, image 2 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement: step 3, image 3 of 3
      • Use one hand to hold the non-locking tab in place, and use your other hand to pull the battery away from the computer.
      Ask FixBot
    1. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: step 4, image 1 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: step 4, image 2 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: step 4, image 3 of 3
      • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. ASUS G73JH-BST7 SD Hard Drive Replacement: step 5, image 1 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement: step 5, image 2 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement: step 5, image 3 of 3
      • Carefully pry the panel away from the computer, by lifting with a finger.
      • There is a small tab where a finger will fit to lift the panel away from the computer.
      Ask FixBot
    1. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: step 6, image 1 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: step 6, image 2 of 3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: step 6, image 3 of 3
      • Gently pull on the tabs to lift the SD Hard Drives out of the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 836
