ASUS G713RC RAM Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
102
All Time:
1,576
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, I will show you how to replace a RAM in an ASUS G713RC laptop. It may seem like a hard replacement at first look, but it will be fairly simple and not time consuming. Not replacing your RAM in time may cause issues to your laptop so it is important to replace it as soon as possible. No worries! This guide will help you replace one.
Hazard Warning: If you have small children, please do not leave any small parts from the laptop that can be easy access to the child. It can be a choking hazard.
Parts
Tools
    1. ASUS G713RC RAM Replacement, RAM: step 1, image 1 of 3 ASUS G713RC RAM Replacement, RAM: step 1, image 2 of 3 ASUS G713RC RAM Replacement, RAM: step 1, image 3 of 3
      • Warning: Do not touch any other components inside if you don't have to. It may result in damage and can destroy your laptop.
      • Remove the seven large screws using a Phillips #00 screwdriver.
      • Remove the four small screws using a Phillips #00 screwdriver.
      • Carefully lift the lid, being careful of the two cables connected to the laptop.
      Ask FixBot
    2. ASUS G713RC RAM Replacement: step 2, image 1 of 3 ASUS G713RC RAM Replacement: step 2, image 2 of 3 ASUS G713RC RAM Replacement: step 2, image 3 of 3
      • Carefully detach the two white cables that are connected to the lid.
      • Set aside the lid.
      Ask FixBot
    3. ASUS G713RC RAM Replacement: step 3, image 1 of 3 ASUS G713RC RAM Replacement: step 3, image 2 of 3 ASUS G713RC RAM Replacement: step 3, image 3 of 3
      • Carefully lift up each gray bar.
      • It is important that you don't completely remove the gray bar.
      • Remove the RAM.
      Ask FixBot
    4. ASUS G713RC RAM Replacement: step 4, image 1 of 3 ASUS G713RC RAM Replacement: step 4, image 2 of 3 ASUS G713RC RAM Replacement: step 4, image 3 of 3
      • Insert each RAM stick under the gray bar. Push until you hear a click.
      • Hold down the gray bar to make sure it is flat and secure.
      • It might be a bit bumpy, but it is nothing to worry about.
      Ask FixBot
    5. ASUS G713RC RAM Replacement: step 5, image 1 of 2 ASUS G713RC RAM Replacement: step 5, image 2 of 2
      • Reattach the lid by connecting the white wires to the base.
      • Plug in the white wires on both sides. You want to plug them in thoroughly, otherwise, your laptop won't turn on.
      Ask FixBot
    6. ASUS G713RC RAM Replacement: step 6, image 1 of 2 ASUS G713RC RAM Replacement: step 6, image 2 of 2
      • Line up the lid to the laptop.
      • Tighten the seven large screws using a Phillips #00 screwdriver.
      • Tighten the four small screws using a Phillips #00 screwdriver.
      Ask FixBot
Finish Line
2 other people completed this guide.
Javier Bobadilla
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 102
All Time: 1,576
