Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Remove the battery, using release clips.
Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
Remove HDD and RAM cover
Locate Wifi Card
Remove the antenna cables using a spudger tool.
Remove the Philips screw The Wifi Card will pop up and should be easily removed.
4 other people completed this guide.
