Up to 20% off select tools
ASUS F550 RAM Replacement
Views: 5.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
116
All Time:
5,619
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 1 of 2 ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 2 of 2
      • Remove the battery, using release clips.
      • Ensure device has no residual power by attempting boot once battery is removed.
      • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
      • Remove HDD and RAM cover
      Ask FixBot
    1. ASUS F550 RAM Replacement, Remove Ram: step 2, image 1 of 2 ASUS F550 RAM Replacement, Remove Ram: step 2, image 2 of 2
      • Release securing arms and remove RAM.
      Ask FixBot
Author
with
Ryan
1,519 Reputation
14 Guides authored
3 Guide Comments
Pretty sure only 2 of the 4 screws need to be removed.
tobiaskuhn - Reply Share
Can confirm only two screws required removal to enable access on my model F550C
Have successfully replaced HD once, but had slight issue getting it recognised
which is more of a BIOS issue, helps if you have a seperate bootable USB drive
but once recognised and OS installed, have several times swapped between the two
HDs (one Win8, one Linux - eventually plan to only use linux on this system).
Regards
Mike.
mihaly_k - Reply Share
Yes only two need to be removed, however I initially wrote a tear down to gain access to the network card etc and the way ifix it is structured for guide creation these steps are in fact used in that longer guide. I've amended the instructions now so hopefully they are more clear now.
Ryan - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 116
All Time: 5,619
