Up to 20% off select tools
ASUS F550 HDD Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
94
All Time:
7,196
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 1 of 2 ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 2 of 2
      • Remove the battery, using release clips.
      • Ensure device has no residual power by attempting boot once battery is removed.
      • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
      • Remove HDD and RAM cover
      Ask FixBot
    1. ASUS F550 HDD Replacement, HDD: step 2, image 1 of 1
      • Remove 3 5mm Phillips screws
      • Slide HDD caddy back, remove using the black pull tab.
      Ask FixBot
    2. ASUS F550 HDD Replacement, HDD Removal from Caddy: step 3, image 1 of 1
      • Remove 4 Phillips screws, 2 per side
      • Remove HDD from caddy.
      Ask FixBot
5 other people completed this guide.
Author
with
Ryan
1,519 Reputation
14 Guides authored
1 Guide Comment
What is the spec of the hard drive? SATA 2.5"? Any max capacity or other restrictions on what drops in?
mrgilbe1 - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 94
All Time: 7,196
