Up to 20% off select tools
ASUS Eee Pad Transformer Back Panel Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
103
All Time:
4,743
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Repairing a damaged back panel is very important, the back panel protects all the inner workings in the tablet and needs to be in good condition to prevent permanent damage in the device. Removing the back panel also allows access to everything inside of the device and is an essential first step to all other repairs involved with the TF101 Tablet.
    1. ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: step 1, image 1 of 2 ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: step 1, image 2 of 2
      • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
      Ask FixBot
    2. ASUS Eee Pad Transformer Back Panel Replacement: step 2, image 1 of 3 ASUS Eee Pad Transformer Back Panel Replacement: step 2, image 2 of 3 ASUS Eee Pad Transformer Back Panel Replacement: step 2, image 3 of 3
      • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
      • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
      Ask FixBot
    3. ASUS Eee Pad Transformer Back Panel Replacement: step 3, image 1 of 1
      • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
      Ask FixBot
    4. ASUS Eee Pad Transformer Back Panel Replacement: step 4, image 1 of 1
      • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
      Ask FixBot
    5. ASUS Eee Pad Transformer Back Panel Replacement: step 5, image 1 of 1
      • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
      Ask FixBot
    6. ASUS Eee Pad Transformer Back Panel Replacement: step 6, image 1 of 2 ASUS Eee Pad Transformer Back Panel Replacement: step 6, image 2 of 2
      • Remove back panel by pulling away from the remaining device.
      Ask FixBot
4 other people completed this guide.
Author
with
Sandy Babich
1,909 Reputation
5 Guides authored
Cal Poly, Team 13-9, Forte Fall 2014 Member of Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Members
72 Guides authored
1 Guide Comment
what can I use to stick back the metalic edge?
Cathy Madzimure - Reply Share
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 103
All Time: 4,743
