ASUS Eee PC 1018P Battery Replacement
    1. ASUS Eee PC 1018P Battery Replacement, Battery: step 1, image 1 of 1
      • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
      Ask FixBot
    2. ASUS Eee PC 1018P Battery Replacement: step 2, image 1 of 2 ASUS Eee PC 1018P Battery Replacement: step 2, image 2 of 2
      • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
      Ask FixBot
    3. ASUS Eee PC 1018P Battery Replacement: step 3, image 1 of 3 ASUS Eee PC 1018P Battery Replacement: step 3, image 2 of 3 ASUS Eee PC 1018P Battery Replacement: step 3, image 3 of 3
      • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
      • Pull the battery pack up and away from you to completely free it from its recess in the case.
      Ask FixBot
2 other people completed this guide.
Daniel Rodman
309 Reputation
2 Guides authored
Cal Poly, Team 8-13, Maness Winter 2012 Member of Cal Poly, Team 8-13, Maness Winter 2012
CPSU-MANESS-W12S8G13
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 36
All Time: 3,281
